So the rollout of the B-21 didn't reveal much about it... no dimensions, expected performance.... nothing. Kinda expected I guess. And with just a head on shot, there's not much to go on beyond what we already knew... which was nothing.
There is one big takeaway though, it's not near as big as the B-1 or B-2 it's (supposedly) replacing. The main landing gear consists of two, 2 wheel bogies. We can assume a fair bit from that. Both the bombers it replaces use 4 wheel bogies. The 8 tires are required to spread the weight of the aircraft on the tarmac and runway without unduly damaging to surface.
Both the B-1 and B-2 weigh in somewhere around a half million pounds loaded. The B-21 won't come anywhere close to approaching that.
I think the nearest approximation we could compare to would be the Boeing 737. It uses 4 mains in a similar 2 wheel bogie setup. Depending on version , it loads out to about 175,000lbs.
Given that load distribution on the ground is a prime factor in design, I'd expect the B-21 to be somewhere around the 175-200,00lb mark fully loaded.... less than half the older bombers.
If we were to apply the old WWII standard of light, medium and heavy bomber, this one would likely be classified as a medium bomber.
