Just Ride.
Should this ride thread be just a.... well, thread? Or should there be a dedicated Forum topic?
  • Yes, it's own topic in the Forums
    Votes: 19 90.5%
  • Nah... threads good enough.
    Votes: 2 9.5%
  • Total voters
    21
  • Poll closed .
Thank you 40north, drgonzo.
The pipes are for the deer. 4;20 am is leave time for work.
Lots of farm land with tons of deer. No respect for the stock pipes at all,
now if they don't care about me coming their way a blip on the wick and all I see is white tails leaving.
Seriously increased my mileage also with no changes to the bike.
Straight running she's respectful, I really try not to piss of the neighbors.
drgonzo. It's an 86 XLH. Titled as an 883 and that's what it says on the jugs.
I don't believe it, wayy too fast for an 883.
It's definitely been worked on in the past, mismatched parts, hardware and gaskets.
No real history on the bike, pretty beat up when I got her but a steal at $1.600
Haven't done much to it since I got it 3 yrs ago.
Typical maintenance and elbow grease.
Bigger primary, smaller on the rear, new tires, the pipes. the risers and highway pegs and the tote bags.
Changed out the solo seat. When she blows up I'll measure the jugs and finally find out what I've been riding. :laugh:
Then a full rebuild.
I kept the stock pipes, but added the stainless nozzles at the headpipes, then cut out the "reflectors" at the baffles. (long extension 3/8-24 threaded rod with hole saw. She's more loud than stock...the baffles are by-passed, and the cops less likely to take an interest ;) since she looks stock. The horizontal crossover pipe is supposed to give a better power curve with less peak...whatever...so the stock looking setup seemed best to me. Hearty agreement bout deer. I would do the same as you if I rode at morning or evening, or at night. We have feral swine, they sometimes block the road, and at any time of day. They respond to the noise from a .45 or .357, but not to pipes. Just stand there.. But my experience with actual strikes has been with owls and pheasants and ducks... and they hurt! Anytime of day birds are dangerous. Mine's 883. The spare 1200 is on a stand in the garage. She's so sweet I'll leave her 883...and there's the matter of arthritis in wrists...883 vibrates less. 100 plus is fast 'nuf fer me. And I like the fuel consumption. I can make it from hwy 99 via 36 to the coast on one tank, going to the races at Samoa (Eureka)... I did have many quality problems in the machine, had to pull primary to fix the stupid clip on the shift drum ratchet, which fell off! It's behind the clutch basket.. that was at less than 10,000 miles. C-clip from NAPA and JB weld... Like I shudda "repaired" it with another stock fubared POS Harley clip! I'd have to check to be sure, but clock says some 28 tho today. And she's become reliable. An 02, about the last of the carb-o-tooter'd. If ah had ma druthers she'd be a 1300 cc flathead..it's been done, tho I am not sure about the cc's of the flathead, a one off some fella with too much money built, ah seen pictures. At the design level I wish she had a timed rotary valve crankcase vent system like a WLA, the little flappers in the heads are inadequate, from 90 degree adaptors ran dual 3/8 hoses down to drip on the road. Otherwise oil weeps at pushrod tubes. Lowered the azzend a bit too. Solo with bags. I put the tool kit up on the bars with shorty risers - where it defects the wind a little - moved the turn signal lamps off the bars and onto the upper tree. Best regards.
Finally felt good enough to get out and ride. Stopped by this beaver pond and the bullfrogs were really trying to out do each other. I could hear them before I even shut off the bike and took off my helmet.
I took some time for a 50ish mile ride in my area. I stuck to secondary or worse roads though all were in pretty good shape. I wondered west out past Road America and through Elkhart Lake. I was in shirtsleeves and the wind buffeting my shirt unbuttoned it so every other stop sign I had to button up. I was headed to the Holy Land and beyond. The Holy Land is an enclave of Amish or similar in the rolling hills of the Kettle Morraine. There are "Buggy" highway signs. When I managed a gravel pit in the area I had many deliveries there. Well, on this little venture I found many roads I had never been on. I had been heading to Pipe in Fon Du Lac county but got sidetracked.
I found this little road and had to wander up it. This is at the edge of the Kettles "Kettle Morraine" but it was time to turn back eastward. I didn't make Pipe. Pipe rises above the eastern shore of Lake Winebago. It is the west end of continous limestone shelf that runs under east central Wisconsin, under Lake Michigan, Huron, Ontario and ends at Niagra Falls where it erode away a few feet every year. The beauty of that limestone shelf is that there is always ground water for wells above the shelf, 50-200feet below ground level. That shelf is part of our shoreline in town. Anyway heading east I found one of the few squiggle signs in my county.
I continued eastward and caught County FF into Rhine Center and past the Town of Rhine Civil War Memorial.
Continuing eastward along county lanes at a leisurely pace I remembered that one of my sisters posts Barn pictures on her Facebook page so when this was right next to the road I had to capture an image.
I don't want to say "fortune" but there is pretty good salvage value in those weathered timbers.
Red Bike ran without flaw. I built her to resemble and behave mostly like a stock mid 70s XS650. She is delivering in spades.
It's all Jim's fault.
dug my way back to it, drug it out, changed a dead battery, and three kicks later it was running.
Knocked off some dust, aired the tires, and rumbled the country roads for a bit.
Well aren’t you full of surprises! Nice photo, nice bike too! 😎
Sounds like you're "snortin" the good stuff Gary!! :cheers:
It was 98* today and I had a Triumph Club lunch to attend so instead of taking the Spitfire and suffering the heat, I took the neglected FJR. It was a 65-mile round trip to the mountain town of Dahlonega and back. On the way home I stopped in the "ghost town" of Auraia snapped a pic in front of the only remaining building, the General Store. Auraia was the first gold rush town in 1828. The store was open as recently as 1997.
It was 98* today and I had a Triumph Club lunch to attend so instead of taking the Spitfire and suffering the heat, I took the neglected FJR. It was a 65-mile round trip to the mountain town of Dahlonega and back. On the way home I stopped in the "ghost town" of Auraia snapped a pic in front of the only remaining building, the General Store. Auraia was the first gold rush town in 1828. The store was open as recently as 1997. View attachment 329631
I do miss that place!
Nice! What a cool old building and a great photo! 👍🏻
Any excuse for a ride I say.
The good warm sunny weather of the past few days is changing. Today in South Wales we have clouds with sunny intervals with a 2% chance of rain. So today I am taking Taffy to work instead of the tin box. I decide to take the country lane 20 miles following the coast. Sadly this road is plagued by 'fly-tipping' issues; but at least its quiet and the fields and trees are green.
Yes the images are real. The one with the tires is at the start of the journey on a side road that is a dead end.
The other image is one of 3 overnight fly-tips along the open road towards Cardiff. These fly tips are a weekly occurance by irrisponsible builder, home owners and Pikies (Gypsys) unwilling to pay to use council tip sites. This has to be cleared by the council which we tax payers ultimately pay for.
Further along we come to Cardiff Bay area. A great place to spend a day; plenty of resturaunts, historic buildings, places of interest and a fantastic theater. The Bay area created by a barrage built across a rivermouth enclosing the old docks of Cardif. The historic port docks were the main location for Welsh coal exports during the industrial revoloution.
Finally we arrive at my current workplace. Taffy is resplendent parked alongside all the Triumphs outside Bevans Triumph delaership.
Sadly I don't work at the dealership; I run the furniture store next door!
Looking forward to a pleasant ride home later.
Cheers
Ads. :bike:
Thank you for the Cardiff tour. What a scourge those fly-tippers are - Wales is a beautiful country and then people come along and do that.
I'll bet the Triumph owners were casting envious glances towards Taffy . . .
Yes Taffy has caused a minor stir here. All the staff from Triumph came out for a look and chat about the bike. Most customers of Triumph also have a double take when they see it too.
Thank you for the Cardiff tour. What a scourge those fly-tippers are - Wales is a beautiful country and then people come along and do that.. .
Sadly there are "fly tippers" here too. More common is tipping trash in small business bins (3 cubic yard dumpsters) or if they are locked, on the ground around them. Then the business owner has to clean up the mess.
A local guy here has an '04 that's been rode hard and put away wet. 45k on the clock. He owes a friend of mine $1700 and wants $2500 for the bike. I offered him the $1700 he owes my friend. The bike runs good, but there's so much bad cosmetically that it would take a lot of $$$ in parts and labor to make it a nice bike and you can find good ones all day for $2500-$3500. We'll see.
TAFFY CAUSED A STIR....!
Yesterday Taffy was causing much interest at the Triumph dealer next door to my work place.
Today Geoff Bevan (Triumph Delership Owner) called in to see me.
I have known him for some years and he has previously offered a test ride on any bike in the dealership; but I never found the time or was too far away.
He said to me ''Nice bike that Yamaha Adam; maybe you should try one of my machines?''
So I agreed, and sttled on trying bikes from opposite ends of thier range.
TRIUMPH SPEED 400
First up will be the new Triumph 400. 40 horses and just 27 ft-lbs. Should handle well.
Build quality is fantastic for what is an entry level bike. Price from £4,995.00 Thats cheaper than some Royal Enfields!
TRIUMPH ROCKET 3 GT
A bit intimidated by this beast. 3 cylender 2458cc monster engine.
Torque is 163ft-lbs and a full 165 horses through the back wheel.
At £22,695.00 (£24,000 for the Storm version) I dont think I will be shopping too soon.
What a contrast in machines. Booked in for next Wednesday, weather permitting.
I will let you know.
Ads. :bike:
