Kick Starter Shaft Repair.
Not exactly sure mine is either. We'll find out. :whistle:
@Jim, I think your Atlas is similar in size to my Logan 820. I have knurled plenty of knobs, thumbwheels etc., with what amounts to a single-point knurl (where the lateral force is being transmit through the cross-slide, not through a clamp-style knurler) so I think you should be ok. Minimum stick-out from the chuck, obviously, and a live-center if stick-out is unavoidable. Compound-rest set parallel to the cross-slide and I also consider it important that you minimize the lateral offset of the knurl from the centerline of the tool-post bolt, if that is possible. Carry-on!
...and a live-center if stick-out is unavoidable
Been meanin' to bring that up....
My live center, like prolly most of us here, is Chinese. Don't get me wrong, it works just fine, but I'm concerned that the side loads from knurling will ruin the bearings inside it.
So I'm thinkin' I'll use a dead center instead. I don't see any reason why that won't work.
Anyone see a problem with that?
I don't, dead center with lube should be fine.
Would it be worth it in the long run to replace the bearings in the Chinese live center with American made ones from Timken?
Good idea, but that's way down on my to do list. For now I'll just avoid serious side loads on it.
Also, do you plan to case-harden the splined end once you're all said and done and verify it fits the kicker boss?
I ran a file across it in various place... it's not hardened. Acts like plain old mild steel.
I myself would harden it. I'd rather have the splines on the shaft wear the kicker boss female part down since that seems easier to replace.
Every lady I've ever met prefers a hardened shaft.
Progress report? :cautious:
The kicker boss showed up this evening. At first glance the splines are a fair bit smaller than the shaft I previously documented. I don't have the ability to exactly measure the splines... measuring tools or measuring ability... dunno.
Anyway, I previously measured 1.5mm on the DT250 ( :umm: ) shaft. This RD200 boss looks to be a little over 1mm. Looking at my fingers will give you an idea on how small this thing is.
So I measured, as best I could, the diameter of the hole to the outside of the splines. Near as I can tell, it's about 13mm... which agrees with the rough measurement I took on what was left of the shaft splines.
I dug up some 1/2" rod that measured at 12.55mm and cut up a few test pieces. I used the 1.5mm knurling wheel on my first try. It was ugly. Not sure how to describe this, so bare with me here...
It made a mark in the rod at 1.5mm increments as it traveled around and when it came around to the marks it already made, it didn't fall into the same pattern. It cut just short of the mark and started making marks that were between the two. That make sense? So what it wound up doing was digging in between the 1.5mm of the wheel teeth, but not quiet centered between them. With me?
When I pressed on and kept forcing it, like the guy in the video, it just started chewing up the splines it already made (unlike the video).
As you can guess, it didn't line up with the splines in the boss.
Next up I tried the 1.0mm wheel. Had better success with that. No "double cutting" on the splines. I won't call it a perfect match to the dia of the shaft, but it's pretty damn close.
Unfortunately, 1.0mm isn't the correct spline distance either. It doesn't match the splines on the boss.
So, near as I can tell, the correct knurling wheel size is 1.25mm. I measured the dia of the shaft after knurling and came up with 12.98mm, so I think I'm on the right path with a 12.5mm shaft, I just need to find a 1.25mm wheel.... sigh... :(
@Jim, the issue of double-cutting of the knurls struck me the other day as I was thinking about this... The diameter of the shaft you intend to knurl needs to be either 1:1 with the circumference of the knurl, or larger/smaller by an integer-multiple of the arc-length of one knurl tooth... I am not making this a statement-of-fact, but more of a hypothesis. Does this make sense?
dunno; heat the shaft red hot and hammer the kickstarter on?
maybe both?
do the heat hammer to get your correct tooth count spacing STARTED on the end of the shaft now set it up and knurl . The teeth marks from the hammered in kicker should help guide the knurl to make the correct number of teeth. Are you lubing the knurler?
@Jim, the issue of double-cutting of the knurls struck me the other day as I was thing about this... The diameter of the shaft you intend to knurl needs to be either 1:1 with the circumference of the knurl, or larger/smaller by an integer-multiple of the arc-length of one knurl tooth... I am not making this a statement-of-fact, but more of a hypothesis. Does this make sense?
Yes it makes sense. That's about what I figured too.
