Plenty of lube.do the heat hammer to get your correct tooth count spacing STARTED on the end of the shaft now set it up and knurl . The teeth marks from the hammered in kicker should help guide the knurl to make the correct number of teeth. Are you lubing the knurler?
Hammering the boss on the shaft is a possibility, but that'll be a last resort.
f around with an aluminum shaft til you get it dialed in.
