This is also true.
The rudimentary app I'm using won't cut it. The only means to change the dia is to change the tooth count.View attachment 365962
I very quickly made a little model, based on a ½" OD shaft, with the teeth being 60⁰, and 30t.
Can change it and send the 3D model if needed....?
I think I came up with 1.27mm. So I'll try and find a 1.25 or 1.3. If I strike out, I can always try the 1.2.
Where's the splines?
...and he ...scores!!! And what about the same part on an XS650 rear brake?Plan B.
Or is it C... or D....
Been down in the basement workshop cleaning and organizing. All my bike projects have parts scattered here and there (mostly there). Decided a little organizing is in order. This is a rolling parts shelf that now has RD200, RD350 and DT250 parts on it. Not done, but it's gettin' there.
Anyway... I noticed something on the DT rear brake plate that caught my eye...
See what I'm talking about? Have a closer look at the cam to operate the brakes.
The splines on it are a perfect match for the kicker shaft splines. 30T and the same diameter. I found a NOS one on Ebay for 16 bucks to my door. Soon as it shows up I'll do some measuring and see if I can just graft it on the end of this kicker. The one on the DT brake plate is a little buggered, so I can use it there if I go back to plan A. Nothing ventured, nothing gained, as they say.
Stay tuned.
Dunno. I'd guess it would be bigger but I don't have one to compare to....and he ...scores!!! And what about the same part on an XS650 rear brake?
