Ben10
Hi guys! I've been getting some mean kickback and the carbs are spitting fuel when I try to kick start it. I found that if I flip on the choke, it'll kick back and spit fuel out the carbs almost every single time when kickstarting , but right after flipping off the choke, it'll start up in one or two kicks with little to no kickback and no carb spitting. I've already checked the timing and it's right on the marks, maybe even a bit retarded. Valve clearance is good. I'm running hugh's complete cdi system so cam chain tension can't be the problem. Cleaned and synced the carbs. Float levels are good. Plugs are black and smell like fuel. I'm guessing either there's something wrong with my float needles or my idle circuit is way too rich and flipping the choke on overflows the carbs?? I am at my wits end and would like some direction.
kickstart only with capacitor
vm34 carbs
Pilot jet - 17.5
Main Jet - 165
6f9 needle
159 P-5 needle jet
2.0 slides
vm34 carbs
Pilot jet - 17.5
Main Jet - 165
6f9 needle
159 P-5 needle jet
2.0 slides
