I've been looking for that but can't find itI would make sure you’re not feeding power through that switch in the off position. Even if you kill the ignition with a switch a trickle to other components may cause problems.
Glad you said that I was thinking you were talking about the black wire from the coil. So anyways are you saying that I should put a toggle switch on the black and white wire between the relay and the cdi box? Or something more clever because it will have to go to ground not just break.I find it hard reading a big block of text try breaking your posts into paragraphs or put spaces between sentences.
Reading you had your bike painted , have you got good clean paint free ground connection for the side of the kill switch or relay that connects to ground.
Paint is a good insulator.
Use the relay to switch the black white to ground. Energise the relay coil from the terminal on your run /start switch that is live in the run position.
To confirm the black white is not a ground wire , it is the wire from the ignition module that connects to ground to stop the sparks.
The ground wires from the ignitor are black and black /red and remain connected to ground .
No, the key is the start button. Just like a car. Run/start/off all in one key.Maybe a dumb question but can you start the bike with the key in the off position?
Yes but with the key off have you kicked it to see? If it still runs after the key is shut off it may always be on.No, the key is the start button. Just like a car. Run/start/off all in one key.
So, I don't know if I mentioned this yet but yes all grounds are clean and everything seems to function correctly. It just won't shut off which I know means something wrong. Anyways I'm about to wire the kill switch and I noticed something. I will include a pic of the relay drawing. I am currently using 87a for theSorry if you are confused.
The black white wire from the control box when connected to ground should stop the ignition.
You can use a switch or the relay to do this.
To use the relay wire it as shown on the diagram. The numbers can be hard to see , take a photo with your phone and mag it up to see the numbers .
If you put a jumper wire from the black white to ground does the ignition stop sparking?
Have you checked the ground connections are clean and paint free ?
If using the relay can you hear the relay coil working when you turn the key on and off.?
If using a relay have you got the wires connected to the correct pins on the relay as per the diagram ?
As you had the wiring working then pulled it apart for painting the place I would look are for wiring connection errors or paint/ dirt under earth connections.
Have you got a good electrical connection between the motor and the chassis where you are grounding the black white wire. Could be paint under the engine mounts . To check run a jumper wire from the motor to the chassis again good clean connections needed for a valid test.
