Seems like an upgrade to more modern front end is the way to go. Takes care of the axle size, fork tube size and more modern damping technology
A very good point
Unfortunately all the braces I’ve found are for the 35mm forks. Might be that one of the tube style (HHB, mikes) could be made to work but would require some massaging and you’d want to be sure it’s doing more good than harm in terms of forks sticking.Anyone have a fork brace or braced fender for 34mm forks? Or know where to buy? 74 TX650.
There's a stiffener in my OE fender, but it's not really a brace.
slippery slope.This may not be an option for you, but my ‘76 had forks that were completely rusted. I had a ‘77 up front end kicking around, so I swapped in the complete front end, and did the gold valve emulator upgrade at the same time plus the fork brace. That stiffens up the whole front end and stops a lot of the dive under braking.
I think he means that at some point it’s easier to lift your wallet and drive a new bike under it.What's it all mean, Gary?
Nothing interchanges between years?
We could use a cheap fix like this for the XS650.Stacked the springs on that one!
This is exactly what I did. Bike is a Frankenstein’s monster so I don’t care about preserving any particular year’s components and honestly accumulated the parts fairly cheaply…then you can easily add a fork brace. Double bubble. Kinda a bummer it seems to be all or nothing re: 34mm vs the 35mm.Gary and I have been down that road. 35mm forks means new trip trees, instruments, brakes, the whole smash. All I wanted was a fork brace option.
Wonder how that goes, knurling hard chrome?Knurling fork tubes.....this could be a new business opportunity.![]()
racetech is usually good at answering questions. maybe call themI have a buddy with an '76 XS, we compared inner tube ID to my '74.
It was...(wait for it) 25 thou larger! 1mm.
Why would the aftermarket offer different springs for TX & XS if both springs go down the tube? Hmmm.
Anyone have thoughts about damping action improvement ? Minton mods don't work, totally different damper config.
I'm wondering if one of Mike's knock off gold valves might be adaptable? I've never seen one, so I'm clueless as to one might be turned down to fit a 34mm fork leg.
