Dunc
Are you using the Porsche style tappet adjuster? Make sure it's not catching on the lip of the valve retainer. See if you can put a finger on the tappet to feel the click.
Wasn't there a design change on the valves and retainers?Yeah, that's a pronounced and odd noise with which I'm not familiar. The nature of it (slightly tinny) sounds like it may involve valve springs or retainers.
The keeper/retainer/stem doesn't look quite right to my eye (good pic previous page). Can you tell us about your valve train parts and their source?
Yep, maybe mid-year '73 (256)-'74 (341)...looking for the BulletinWasn't there a design change on the valves and retainers?
That's why I questioned chain tension on the last page. Only 2 things (that I can think of) could cause a click... the chain, as load on the lobes goes from pulling to pushingIt feels like the click is immediately after the cam peak. Like it's jumping down the slope of the cam.
I've found that head gaskets that haven't seen any heat cycles (ran) yet are generally safe to reuse. Same on the base.Thanks JP, looks like I know what I'm going to be doing this weekend.
Questions (which really boil down to: When is it necessary to install a "new" head gasket?).
1) Loosening and removing the rocker cover, relieves pressure on the Head gasket, would this not cause it to leak? Does it need to be replaced? or - other option? (I feel like I'm over thinking this...)
2) If the (top) head were removed - has anyone re-used a Head gasket?
3) Same thing for the Base gasket? At what time does that need to be replaced, or sealant reapplied?
