Jab458
Hey all,
Recently did an engine rebuild on a ‘79 447 engine. It was a full top end job with a 1mm overbore, and I installed a crank from a donor engine since I found that the small ends of the existing one were beyond toast.
It’s been running great and obviously the top end job stuck, however I occasionally hear a good clunk from the case, especially when using the starter motor and it’s struggling to start.
I saw some threads about similar noises occurring when the alternator magnet wasn’t torqued properly so I removed the side covers to check torque. It’s got the 50-54 ft-lbs that is expected. I did find though that the the whole crank shaft has lateral movement, enough to make a clunk in the case. When I move it from the alternator side I find that the same movement happens on the clutch side, so I suspect the whole shaft is moving back and forth. I can only imagine this is not a good thing.
My question for you all: is this a symptom of main bearing failure? I’m going to go back through my photos taken during installation to see if I missed some washer that might prevent this.
Would love to hear some opinions, suggestions, and to be told I’m missing something obvious before I decide to tear the whole thing down and build a new crank for it.
Video of crank shaft moving linked below.
