$25! Yikesā¦. but thats USD, equivalent to $120 CDN and it has longer hoses than mine.
they do tend to want to sit just a little way to one side. can't remember if it's before or after.Ponderin' a 360Ā° twin.... valve openings (cam) on the other cylinder might not allow you to set the crank on TDC.
Dunno.... never tried it. Now I'm curious.
Some coca chewin'... leak down test, why? Just polish.More cud-chewin'...
Thx for the advice. Iād rather go āoverkillā than have a mishap of my own. The bike is on a lift with the front wheel in a chock so the rear brake and breaker bar should be sufficient. Iāll post test results.Had an embarrassing mishap many years ago, so I follow this drill. Put the bike in gear, chock both wheels, lock the crank with a big old breaker bar braced against the floor, tie back the front brake lever, and run down the rear brake adjuster hard (drum type) or tie down the rear brake pedal (disc type). Overkill? Probably, but it's easily done. Don't worry about staying exactly on TDC, what counts is that the valves stay closed. You have some slack there, and you can get more by backing the valve adjusters off all the way.
Thx grizld1. Really didnāt want to pull the engine if I didnāt have to. Itās just a second bike so if it runs ok, thatās good for me.You've made a good decision, bosco. 10% or less is the standard for street motors, so yours ain't broke and doesn't need fixing.
Iāve only run the engine 10 minutes tops. Rebuild was done over 3 years ago (2 p.o. ago). The guy I bought it from never rode it or ran the engine. Considering how loose the head was, if it had been run, the engine would have been soaked in oil. Motor was clean as a whistle and the guy I bought it from never cleaned it.How many miles you put on it so far?
