T250tut
Hi All
1977 XS650D UK spec
Wiring is fine and all works OK - not sure if ignition switch is original as I can use position 2 on the ignition OR the on off on the right hand switch to work the lights
BUT
when i use an LED bulb in the rear T/L it glows faintly with ignition on / lights off - it does work correctly when the light are switched on as both tail light and break light.
all the dash warning lights / systems are working properly and no faults are triggered
I have an LED H4 headlight bulb in the front as I have on all my other bikes circa 1970's and I have not had this issue before so whats different with the XS???
Used bulbs from these guys in everything else and cant recommend them highly enough for the improvement they make to 60's & 70's Japanese 2 strokes
https://www.dynamoregulatorconversions.com/the-cdrc-online-shop.php
Cheers
1977 XS650D UK spec
BUT
Cheers
