led
Wingedwheel
It wasn’t me…..
Waterford, MI
The bulb I put in my tail light is very bright and when I hit the brake it will flash brighter for a moment but doesn’t appear to stay much brighter. I’d prefer it the other way around.
gggGary
Just call me squirrel brain
XS650.com Supporter
Baraboo, WI, USA
I've run into "not enough difference in brightness" LED bulbs too.
jetmechmarty
Project collector
XS650.com Supporter
Coldwater, Mississippi
The lamps I linked in post #8 went into the lights on my Eleven Special. I can attest to the fact that those go significantly brighter when the brakes are applied. There is no mistake. (I am not running an LED headlight linked in the same post, only the red and amber bayonet bulbs.)
gggGary
XS650.com Supporter
Baraboo, WI, USA
Something like this may be the cat's PJ's
https://www.ebay.com/itm/1930211373...1291&msclkid=cc9b627551c11e426d69066279736054
gggGary
XS650.com Supporter
Baraboo, WI, USA
bosco659
XS650 Guru
XS650.com Supporter
Oakville, Ontario
I just use an 1157 white replacement led bulb in my tails and they work fine. The XS used to have a red / white led bulb but it wasn’t very bright. It also did not work with my brake light modulator.
Wingedwheel
It wasn’t me…..
Waterford, MI
Mine was just a dual filament 1157 that I replaced with the equivalent LED replacement (supposedly) I’m not sure if the headlight has anything to do with it on mine but it has the same brightness with the lights off. I have a feeling it’s the LED.
