Extended intakes between head and carbs is available for VM, DellOrto and other non-linked carbs. But for the stock BS34/38, EX500 carbs, Mikuni TM/RS 34/36, and other linked carbs, the frame tube makes extending the intakes difficult.
Unless you make them long enough to put the carbs behind the tube, that is. Has anyone tried just that?
I am pretty sure the stock intake length may be too short for optimal intake resonance in the rpm band most of us use.
Extending the intake length with velocity stacks would obviously be an option, but then the diameter would be larger/ gas velocity lower. And I assume higher gas velocity combined with a longer intake would give the "slug" og air and fuel more mass and momentum. At least that seems intuitive to me.
