• It's time to vote for the bikes you want to see in the 2025 XS650 Calendar! Vote here!
Longer shocks = chain fouling
nighthog
A bit of a bike hacker
Chippenham, Wiltshire, UK
Hi all, on my '82 I fitted 340mm / 13.5" Hagon shocks to both improve the damping and to raise the rear a little, helping with the handling. That's all been just fine, but it has reduced the chain-swingarm clearance just enough enough so the chain chews up the grease seal at the end of the swingarm and can even dig into the swingarm itself a little. And yes, I do try to keep it correctly tensioned.
I've tried various ways to protect that area but with no success. I'm currently fettling a TX750 swingarm to replace the standard one and would like to address this before fitting it - I know others have used longer shocks to good effect so must also have had to deal with this issue.
If anyone has an elegant solution to this I'd be delighted to hear about it! Thoughts?
Cliff
On my 77 model, I have/ had the same issue. I ended up making a plastic bushing that fit over the swingarm bearing tube. A more properly designed chain slider, as found on many newer bikes would of course be better.
The actual root cause of this problem, is the primary drive ratio, that forces the use of very small rear sprockets. Other road bikes often have 37-43 tooth sprockets, that lift the chain away from the swing arm. So the ultimate fix is a new set of primary drive gears, from Ivan Hoey, Heiden or Smedspeed.
Thanks, and changing the primary drive gears is no doubt the best fix, but I'm looking for something considerably cheaper! I was hoping there may be a chain slider for another bike that could be simply modified and fitted, for example.
Unfortunately there aren't many round tube swing arms that came with chain sliders. It is possible the XT500 had something.
Sounds like you need a chain slider, as found on almost all dirtbikes these days. Between Amazon, eBay and whatever other favorite online vendors you may have, you should be able to find a slider that could be adapted. I have often used plastic cutting boards, as found at your local household goods retailer, as a source of plastics for such purposes. The material, whether nylon or whatever its actual composition is, can be readily cut, machined, bent/molded and drilled. Time to get creative!
I glued a piece of red rubber sheet on top of the swingarm. Set-up is 13" shocks and 32T rear. Chain doesn't rub at rest, but obviously makes contact while running - works good.
Since no one asked.
stock XS swing arm vs Radian arm with same amount of parts attached
stock 10.05 KG
Radian 9.95 KG
I just stuck the guard on the XS arm should be easy enough to make an attach point. Some enterprising soul could 3D print a guard?
Note how the radian rectangular tubes are thicker (taller)at the pivot, chain wear on the radian arm behind the hard rubber guard.
It's slightly longer about 1/2" 13mm
The radian axle is 17mm the whole length, the XS650 20mm, necked to 17 at the thread. It's straight forward to open up the radian axle slots, adjusters to accept the 20mm axle.
Radian arm has a plastic chainguard, prolly lighter than the XS steel chainguard.
KIMG2823.JPGKIMG2822.JPGKIMG2821.JPGKIMG2820.JPGKIMG2819.JPGKIMG2818.JPGKIMG2817.JPGKIMG2816.JPGKIMG2815.JPGKIMG2814.JPGKIMG2813.JPG
Key words; radian custum swing arm swingarm pivot shaft axle fit install modify compare dimension size length width height.
