A tip I poached from
@gggGary , to remove those really stuck fork seals, I’ve seen a lot of damage done by guys prying with screwdrivers. If you have a small tire iron, clamp it in a vise and pry against it, like so,
And a word of caution, if you clamp your lower fork leg in a vise to work on it, use blocks of wood and don’t clamp it tight, I had to buy a set of replacement forks from a wrecker, for my XS2, because someone had mashed the lower legs in a vise and made them egg shaped, so bad that the upper fork legs were getting stuck internally.
