so, No new battery yet but I did do some data gathering and going to spell out some things that should be known by many here but may not be known by all (anyone correct a mistake I have and I'll edit)
So, Battery goes to the ignition switch then that output (brown) goes to the Handle bar Volt Meter and to the kill switch.
Out of the Kill switch comes the red with white stripe wires that go to a plug in the headlight, then to wires to the harness that then goes to the + side of the each of the coil inputs. = side of each coil input goes to cooresponding point. Other end of point goes to ground.
Spark activates when the cam OPENS the points
When the the points are closed, 12V is across the coil (points are grounding the - side of the coil).
Transformers (the coils) work on AC or in better terms a change in voltage. The change from 12V across the coil to 0V across the coil produces One impulse high voltage on the secondary (secondary is sent to the plug).
Wires and connectors have a resistance. In simplest terms, Thicker wires have less resistance (of the same metal type and stranding). Good connectors have lower resistance and poor connectors/connections or dirty ones have a higher resistance. Resistance is generally bad in wires but manufacturers didn't use heavy gauge wires to save $ and connectors as they age increase in resistance as they get corrosion or the crimps loosen.
So, as said, I have a handlebar volt meter at the Brown wire that is AFTER the ignition switch. but before the Kill switch.
I hooked up a variable power supply instead of the battery. This PS is strong enough (5A) to run the power but not start the starter motor.
I wanted to see how low I could get the Battery voltage and still get a spark at the plugs.
Here is a simplified drawing of the circuit.
I started by measuring the voltage at the Points with Both points open, Left closed/right open , and Left open/right Closed.
Supply Voltage 12.0V
Both Open:
Supply 12.0V 2.75A
Vhb= 11.0V
VLP = 11.28
VRP = 11.29
Left Point Closed
Supply 12.0V 4.79A
Vhb 10.4V
VLP = 0.028V
VRP = 9.13V
Right Point Closed
Supply 12.0V 4.77A
Vhb 10.4V
VLP 9.18V
VRP 0.025V
So from this, we yield that with points both open (no current going thru coils), Bike is drawing 2.75A (Tail light, indicator bulbs, Rotor coil).
Each coil static current draw is approx 2A. We also know that from measuring the open points voltage of the opposite points, we know the voltage hitting the input to the coil (9.13V) so there is a 2.87V drop in the switches, connectors and wiring from the 2A coil draw. (I don't like that!)
That 2.87V drop is from all the connections, wires and switches. between the battery and the Coils.
Next thing I did was adjust the Battery voltage at the power supply lower and lower to see how low of a Battery voltage I could get and still get sparks at the Plugs. I hooked up my spare plug and rotated the points cam so that one Point was open and the points under test was closed. I then used my finger to manually open the points under test and look for a spark on that plug. This told me how low of a battery voltage will still yield a spark. In each case, the Current went down (as the supply voltage went down)
Left Points
10.0V Battery consistent spark
9.5V Intermittent spark
9.0V weak intermittent spark
Right Points
9.5V Consistent Spark
9.0V Intermittent Spark.
So, as we can see even a pretty low Battery voltage will still give a spark.
I looked back at my video and did some frame freezing and when I lost ignition and the bike was still in gear and motor/alternator spinning, voltages were at 13V+ at the handle bars.
I have a hard time believing the voltage at the battery is dropping too low to give a spark.
I'm more thinking Intermittent connection in the feed voltage to the coils in the harness/connectors or a ground.
Bypass switch to run battery direct to coils will tell us what is going on. If that makes it recover, its the harness. If not, its a ground.
What grounds could be bad? I don't think Battery to frame, cause if that happened the Handle bar meter would go dark.
I cleaned up the Condenser to frame ground.
Points disk to Engine contact? that would be unusual as there are so many contact points for that.
At a few amps, 18ga wire won't be dropping a volt in the distance that the wires are. Those voltage drops are from connections.
