How about using the old regulator as a test .Can it be used with other electrical there
I had one go bad. Hot Causing ignition problems
the rectifier went bad the regulator was still good but i wasnt sure how to repair the rectifier so i got the solid state oneHow about using the old regulator as a test .Can it be used with other electrical there
the compression readings i got in june when i bought the bike were low but within the right tolerance of eachother i think
123~ right cyl
125~left cycl
the reading i just got today was
130 right cyl
120 left cyl
Gary makes some good points. I wouldn't worry too much about the compression numbers or inconsistency. And you will always have a good amount of air pressure in the crankcase when running. I would consider the automotive reg/rec swap that Jan mentioned. But mostly it's common for tiny debris to stick in small holes and passages of the idle circuit. This will result in the"choke only" situation you describe. I would triple check this area and while you're at it possibly up a size or two on pilot/main to better suit your exaust/air box or lack thereof. Nice bike. Have fun and keep us up to date.
i checked vlave clearances and triple checked all carb passages , nothing wrong with either , im gonna research a possible way to check the new solid state reg/rec that i just bought and rule that out but at present i bave a new top end gasket kit, new piston rings, and an engine stand on my work bench ready to pull the motor and do a top end refresh on it to hopefully get some compression back and fix the oil leakGary makes some good points. I wouldn't worry too much about the compression numbers or inconsistency. And you will always have a good amount of air pressure in the crankcase when running. I would consider the automotive reg/rec swap that Jan mentioned. But mostly it's common for tiny debris to stick in small holes and passages of the idle circuit. This will result in the"choke only" situation you describe. I would triple check this area and while you're at it possibly up a size or two on pilot/main to better suit your exaust/air box or lack thereof. Nice bike. Have fun and keep us up to date.
Just disconnect it. it can't cause problems if it's disconnected.im gonna research a possible way to check the new solid state reg/rec that i just bought and rule that out but....
Charge the battery, disconnect the reg/rec and see if it runs OK.
Highly... highly unlikely a reg/rec could cause problems in a points motor, but you can run without it and find out.
its stock charging systemI like that Idea but do we know if it is a PMA or stock Alternator If PMA perhaps the created Voltage needs to be Cooked off
my carbs have had the same jetting since i bought the bike aside from a main jet upgradeits stock charging system
maybe im being thick but i feel like since the problem is only when the engine is warm , and only without the choke on it is unlikely to be an ignition issue ?
my battery is charging fine and my plugs fire on time and orderly
and if you employ the process of elimination that i learned here
if problem arises
1st check spark if spark is good
2nd check compression if compression is good
3rd check carb
i stopped at compression because its lower than reccomended spec and and the valves are within spec thats how i ended up with this gasket kit and piston rings on my workbench lol
