I did oil the new cable but will do it again today. I’ll remove the tank and relocate the cable under the tank mount like yours yo see if that helps. Thx
Hi,Update on the Magura clutch lever and aluminum clutch push rod.
First the Magura lever assembly. Works very well. Has more cable travel than a stock lever. It with the long arm worm gives the push rod plenty of travel. Pull is just fine to me. No problems with clutch dragging at stop lights.
The aluminum push rod makes a huge difference. Very minimal change in cable free play between a cold engine and a hot engine. Set the adjusting screw at the worm at 3/16 of a turn from touching, adjust cable at lever and you are done. I used to get a lot of extra free play when the motor warmed up. Now very little. I like it.
The first aluminum rod I made was out of 5/16 6061AL. Ran it for 1000 miles and checked it for wear. Not bad it had a little wear where the seal and bushing ride. During the time I was testing it I had ordered 1 piece of 8mm 7075AL from China. Took almost 2 months to get to me. Made a push rod out of it. Went to install and it wouldn't fit. It measured .619 instead of .615. F@CK Remembered 2M had posted a link where he found some 8mm 7075AL, found the link and ordered some. Got to me in less than a week. It's even the right size and fits. Made a push rod and installed. I only have 600 smiles on it. Checked it the other day and looks good. Plus it works great.
Last winter I sent Mailman a couple of the 6161AL pushrods to test. He had the same results I had.
If anybody's wants one I they are for sale for $17.50 +shipping. If interested PM me.
Edit: The ones for sale are 8mm 7075AL
Not at this time.Hi,
I'm replacing the worn plates in a 1980 SX650. It's always been difficult to find neutral and the shift has never been smooth. While the clutch basket is out, I'll check the shift adjustment. I have noticed that the shift does get easier as it heats up, so while it's apart, I may as well replace the push rod. Can I still get one of the aluminum rods?
Keep workin' on it. Mines about half that.Although not the perfect test or experiment, I hooked up my digital scale to the lever and gave her a yank. I’m estimating an approximate reduction in pull by about 6lbs. Looking at an old video from my previous test, when the lever was about 3/4” from the bar, the force needed was about 28 lbs. Now that measurement is about 22 lbs. Results would have been more accurate with an assistant but just did it myself with three hands. Sat on the bike and worked the lever - it may be ok especially with a warm engine and oil.
I think mine was about 10-14lbs last time I checked.
https://www.xs650.com/threads/yet-another-clutch-mod-thread.57235/
Nah... you got this. Keep pluggin' away at it.
