600 mile service part 2, valve clearance inspection / adjustment
The mailman brought my socket yesterday, so first thing this morning I pulled my spark plugs. See how tight the clearance is and deeply set they are?
Next remove the crank cover, and the inspection plug from the front of the motor
Rotate the crank until the hashmark shows up in the inspection window and the cylinder is at TDC. Start with the rear cylinder ( photo shows mark for the front cylinder )
Now the valves can be set. Given the lack of room to work, I popped for the Suzuki special tool. I could’ve made a homemade tool, but what the heck, I’m worth it.
So, some were really easy, a couple were super hard to get to but I got er done! Most were within spec, but a couple were a little tight. I bought a used factory service manual from EBay. My feeler gauges aren’t speaking to me right now , I had to bend the crap out of them to get into those contorted covers.
Funny story, on day two when I was pulling the air intake out, I lost a little spring hose clip down somewhere in all that throttle body mess. I must’ve spent an hour looking for it, and finally decided to circle back to it in the morning.
So by now it’s 109 degrees out and I’m sweating like I’m melting. I still have to put some things back on the bike and do my inspections and tightening and lubing, but that stuff is easy. The hard work is done. I’m calling it a day.
It sure made me appreciate how easy adjusting the valves is on our XS650’s!
