Mailman’s Suzuki C50 Boulevard
Mailman
Hardly a Guru
Surprise Az
Bob, curious if there is a forum out there for these bikes like we have here? Just wondering if there are other caveat’s out there to watch out for.
There is a website called VolusiaRiders.com , Volusia was what the bike was called before the name was changed to Boulevard.
The Website is pretty dead, it’s ok for resource material but not much interaction goes on there. They sold this bike for many years, popularity peaked about 12 years ago and the forum activity has since declined.
A couple possible known issues are premature cam chain / and cam chain adjuster wear, has occurred in some bikes. Not a lot.
Also an internal seal in the rear differential has been known to fail.
Those are the only reoccurring problems I’m aware of.
Mailman
Hardly a Guru
Surprise Az
Attempted Tail Light Repair Part ll,
After letting the super glue set up , I started trying to clean up the inside of the lens where super glue had wicked into unintended areas, namely the sides of the lens that had a frosted appearance. I feared this would be challenging, but it turned out to be an easy fix, using acetone and Q-tips, I had it cleaned up in a jiffy.
Then on to the outside of the lens, the glue had penetrated the crack so well that it actually made its way onto the exterior. I used a headlight repair kit, that I already had. Progressively sanding the repair from 800 to 2000 grit, then buffing it with a plastic polisher. My first attempt, I could still see scratches from the sandpaper, so I sanded it again with only the finest grit, then polished it again, then after cleaning it, I sealed it with Turtle Wax Hybrid Ceramic spray. ( I’m gonna give that stuff a plug here. If you’ve never used it, prepare to be amazed )
So after I was happy with the appearance, I ran a bead of super glue around the perimeter and rubber banded the two half’s together and left it overnight.
The next day, I reassembled the tail light and installed it.
412BB723-7682-4CD5-B047-4D052965591B.jpegC94501FB-EBF0-4B6C-88FE-3CBFC360D675.jpeg1B71B623-BF65-4A78-A292-136DB9A56FC7.jpegDA1CADD8-F45D-4993-8A8B-571B85EDE7B4.jpeg09D9282C-CF0A-4639-8204-81377670C64F.jpegF082CED6-08CD-4329-B3AF-1B90C856647E.jpeg
Then I ran to the hardware store and picked up some grade 8 bolts and lock nuts and put the rack back on. And just for overkill, I put red locktite on the nuts! 😁
So all in all, I’m pretty happy with the results. I was able to save the tail light and save myself $350 in the process. If you get within inches of it and look real hard, you can see a couple of small flaws.
Only the carpenter sees his mistakes
But I’m gonna go with Mikey on this and call ‘er good! 😉
Mailman
Hardly a Guru
Surprise Az
I'm taking bets he has those bolts back off, the text filed off the heads and polished up before the weekend's over.......
And or goes back to get button head bolts...........
You know…….I do have a set of SS button head bolts that say A2-70 on the heads. I bought them and never used them, I’m not sure how hard they are. I do like that idea about filing and polishing those bolt heads though! 😉
Mikey
got muscles in his head that ain't never been used
XS650.com Supporter
Waite Park MN.
View attachment 230715View attachment 230716View attachment 230717View attachment 230718View attachment 230719View attachment 230720
View attachment 230721View attachment 230722
The carpenter can no longer see his mistake
Good job!!
gggGary
Just call me squirrel brain
XS650.com Supporter
Baraboo, WI, USA
Mostly musing but it sure would be nice to see a full size bolt shank as the bearing surface on both those pieces of plate.
I get why full thread shank is common on replacement bolts but.............
Jim
XS650.com Supporter
Kansas City Mo.
The airplane side of me wholeheartedly agrees. In my old world good long shoulders was more the norm.
WideAWAKE
Single Fins and Twin Cylinders
California
redacted—
My post was late to the game and was suggesting to use acetone to clean the inside…
Your post actually doing it and the others after had not shown up until after I posted…
Funny little glitch haha.
cra-z1
XS650 Guru
CDA ,Idaho
Looks like it came out great. Nice thing about being retired you have the time to do things like that. When I was working I probably would have just bought a new one!
Nah, I would have tried to fix that one also. Allways nice to save a few bucks if you can. In your case Mucho bucks
Mailman
Hardly a Guru
Surprise Az
Yeah honestly I’ve always been a repairman at heart, mostly out of curiosity to see if I could do it. 😄
