Petcock area paint removal; chatted up a pro painter yesterday. He doesn't strip the paint back, but saw my point and finally said there is no perfect answer.
Thanks for that bit of feed back , I never did get back to my tank did I? I’ve been stalled out working on it.
Here’s where I’m at on the tank right now, I think I’m going to roll the dice with the paint under the petcock. The area around the mouth of the tank was sealed with epoxy by the painter. You can kinda see it under the cap here.
It was very rough so I sanded it smooth, then went over the epoxy again with brush on super glue. Will all of that work or will I be crying in my beer a year from now? Time will tell I guess. One thing is certain , the o ring around the petcocks aren’t cutting it. I had the petcocks mounted, but pulled them back off after a few days and when I did, you could see where the oring had indented into the clear coat in a hit or miss pattern, which tells me it’s not making full contact and a good seal all the way around.
The petcocks are the usual aftermarket affair with these skinny little o rings that are just barely above flush, and the channel for the oring is too deep.
I want to look for some fatter o rings to fill that space, that and I think a little Hylomar.
I did get one original petcock that wasn’t mounted on the bike when I got it. I might think about getting another and rebuilding them. But you can see they came with a fatter black o ring.
And now a tip of the hat to 2M, who suggested a modification to make the gas cap close easier. The gas cap was making contact with the opening while the gas cap was still at a high angle causing the cap to bind and be hard to shut. He suggested a spacer under the bolt which would allow the cap to drop to a lower angle before contact.
Brilliant! Works like a champ. Thanks for the tip Steve! Now if I only had a good shop mechanic that lived nearby to help me sort these carburetors, like ol Bill here!
