Ok, I’ll try to respond to everyone’s comments here.
This leaking battery has a manufacturing defect, it’s leaking around the seal for the negative terminal, the first one I bought was leaking before I ever got it out of the box, as Jim said. The second one leaked in exactly the same spot.
I will be looking at a better quality battery for a replacement. Our extreme desert heat kills batteries so quickly I have been reluctant to spend much money on them, instead I have treated them as disposable. I just plan to replace them every two years. That’s about all they last in our cars too.
My charging system has been modernized with solid state VR-115 voltage regulator and solid state rectifier.
I do have a voltage meter mounted on my handlebars and my charging numbers have been good.
And @GLJ , Greg those tires. My XS2 still had the factory original tires on it when I got it. Those ribbed front tires may be correct, but I would be reluctant to run one. If you never ride on any highway with rain grooves they might be alright, but if you do those ribbed tires are evil handling!
