Nomader
XS650 New Member
I have seen several post about bikes with melted ground wires between the rectifier and the grounding post near the coil. Generally, I'm seeing suggestions that poor ground connections are causing the problem. My question is for those who have actually fixed the problem. Did just replacing the wires and cleaning the connections fix the problem or did wire melting cause other electrical components to go bad and need replacing?
