MikesXS Gen 2 ignition issues.
Alllooksnnogo
New Brunswick, Canada
Hi guys, well its been a journey so far. I have almost completed my xs650 project. A month ago, however, I ended up having an ignition issue. I had mikes xs gen 1 ignition running on the bike for years now. This year I installed a PMA/lithium battery setup with a HHB rectifier. Everything was working fine until I lost spark, diagnosed the issue and found that the set screw to hold the chip board in place in the ignition rattled loose and detonated it. I purchased a new GEN 2 unit from Dime City and installed it. The bike ran but very funny. holding a high rev and backing off slowly, then the bike died. the bike is kick only. I had is running for all of 15 min then kapoot! Nothing and back to no spark. I checked the entire charging system and coil again and good at this point. I am thinking a back ignition unit out of the box. Any suggestions? Am I going nuts here?
jpdevol
Hacker of Frames,Wires and other things
XS650.com Supporter
26187
Hmm...so Gen II is it a red unit with mechanical advance or blue unit with E-advance? What battery and is it holding full charge? What coils are you running on what year bike? What PMA system and a MOSFET regulator from Hugh, or other? Have you checked voltage at the battery?
Alllooksnnogo
Hi JP, thank you for the response. Its the red unit with mechanical advance. I recently replaced the mech. advance unit as well with a new one. Battery is holding its normal charge of 13.15 (lithium) and the PMA is charging. So sorry as if you guys can guess lol....its a 1972 xs650 with a 77' xs650D motor. PMA is mikes and the rectifier/reg is a mosfet from Hugh's.
jpdevol
XS650.com Supporter
26187
As you may know, there's probably no specs for the red trigger mechanism. The goal, then, is to eliminate everything else. If you're getting 12.5VDC to coil + (R/W on OEM harness) then you should be able to ground (briefly) the orange (-) from the coil and get a spark. It was running so the coils should be compatible with TCI ignition (anything prior to '80 XS OEM is not).
Alllooksnnogo
Yes I am having a difficult time trying to find info on how to troubleshoot if at all the gen 2. Is there a multimeter test that you know of? So sorry again. My coil is a newer style high output and I do have 12v at the coil/ Tested the coil as well and have 25M through the wires on the secondaries and 2.5 across the primary. It has to be the new unit but I'm a little bit dizzy from all the troubleshooting lol.
jpdevol
XS650.com Supporter
26187
The ohm test sounds correct - ballpark. Can you jumper orange (-) from coil and quickly touch to bare ground to see if a grounded plug will spark? The exact source of coil (p/n) may help
Alllooksnnogo
Ya, shoot, I thought so on the trigger. I have only one coil, 2 leads for my primary in red/white and the green. then the 2 plug wires. I took an old spark plug and shorted it to ground and nothing my friend!
Alllooksnnogo
Absolutely JP I emailed them and waiting for a response. Thank you very much for the advice. Nice to know I am on the right track for my troubleshooting. Thank you Jet, I agree, I have not heard anything nice either. I am hoping there are no contradictions in my set up with regard to using this Gen 2 and my PMA. I do not think so as these items are sold together as a package.
