Mikey's new to him 73 650
Mikey
got muscles in his head that ain't never been used
Waite Park MN.
We'll call this my build thread although I work at the speed of smell on these bikes I'll post anything note worthy as I get something done
" what's that dear "
"Ya wan't me to do what "
"Oh okay write it down for me would ya and I'll get a round to it real quick" :whistle:
Okay it's a 73 with under 6,000 miles on the speedo ( if the speedo is stock)
The guy I got it from purchased it used in 74 and after awhile it got sold to his brother
And after his brother died a few years ago he got it back
Plates are from 2022 and he's always kept ethanol free gas in it ( when the change to gas came with it )
It definetly has an aftermarket M/C and I'm not sure of the exaust being stock and the inside of the tank looks good
Well enough yammerin for now here's a few pics (so it did happen ) see I know the rules here
Acts as a shimmy dampener... helps prevent it shakin' it's head at speed... with limited success I might add.
One thing it is good for is long straight roads with a stiff crosswind. The kind where you're constantly fightin' the bike, leanin' into the wind. Snug that thing down and it helps a lot.
I considered it indispensable when I was stationed in N Mexico. The high plains was nothing but miles and miles of straight roads... and near constant crosswinds. Never really understood the physics of it, but it does help a lot.
Jim' assembly is missing part #12, which holds the damper at the desired stiffness. #17 is just a thin washer, and 16 is a little rubber washer, and I think they both might be at the very bottom of the rod in Jim's pics, otherwise you can scrounge or make them
The main purpose of the damper is that it is kind of unique and looks sort of funky-cool. I've been riding without it for 4 years on the Super RustBucket (a 73 TX650), including lots of freeway driving. Every once in a long while I imagine very minor shimmying, and wonder if I should install it.
Excellent score on the bike.
Thanks for the diagram !!
How do you manage getting a clear diagram off Partzilla ?
When I start digging into this can the top nut just be loosened and slide the rod in with the various washers put in place while doing this or do I take it apart completely and go from there
New uncharted territory for me
It's luck of the draw. Some of the parts fiches that Partzilla uses are clear, some are not.
I have attached a little secret of mine that 2M gave me a long time ago. It is a foreign version (in English) of a 70-72 parts manual with exceptionally clear diagrams and 99.9% correct part numbers. Of course, 73 has some differences, but is 99% the same as 72.
  • xs1-xs1b-f-xs2-parts-lists.pdf
