Yeah no charging, you need to see a solid ground on the top brush, then any time the iggys on the regulator should provide +12 to the lower brush as needed.The volt meter was reluctant to go above 11.5V but with a few revs did see it jump to 12.0V a couple times
Raymond, that looks suspiciously like a type A regulator. Was that installed prior to your current** problem?I have just checked voltage across the battery - with engine running at tick-over shows 12.01 v, revving to ~ 3,500 same, well the meter flickered to 12.03 but that's probably an artifact due to vibes. Bike is not charging.
Looked at wires to regulator - the brown feed wire shows 12.02V, the green out shows 0V - that's iggy ON but not running.
Looked at wires to the brushes. Both 0V show with bike ON but not running and still 0V with engine running.
Next will take tank and air filter boxes off to look at the fives wires running up from the alternator - three white, one green one black.
** No pun intended.
Brown wire from the alt not plugged in - must have missed it when I did up all the earths. Which has me feeling cautiously optimistic. Tank off to get a better look, plugged into an earth socket that just happened to be available nearby, tank back on, started er up and went for a short blast along the bypass. The volt meter was reluctant to go above 11.5V but with a few revs did see it jump to 12.0V a couple times.
Yes, I've had that reg for years since i first wired the bike. I remember discussion of Type A and B and I can't remember what Missy has - will look back over this thread tomorrow - going to bed now.Raymond, that looks suspiciously like a type A regulator. Was that installed prior to your current** problem?
** No pun intended.
I know you're done a tonne of rewiring, but in the stock configuration a brown wire would be switched 12V.Well, from my confussed understanding, I need a solid battery voltage at the inner brush as soon as the ignition is on but I've got none.
I assumed the brown wire was an earth but now I'm thinking otherwise - could that be the feed I need so to speak.
Tina Turner ruff!?Pleasingly ruff, or simply ruff?
Fairy snuff then.Ruff as in - not as sophisticated as the W800. A fair comparison, they're both middleweight twins, but the XS has a raw edge. More vibes, more clunky on/off the power, noisier, but manages to be fun. Which is better? Which is your favourite child?
