Adam Savage
XS650 New Member
Okay, so I have a 1978 (model year '77) xs 750 triple. I had it up and running a few months back only to find that once it got going it leaked oil from the head-gasket by the cup. Albeit, it didn't run the best, but i could at least (if it weren't for the awful leak) ride it and troubleshoot that way. So it got a complete top end rebuild (by a local shop, not myself). I got it back, ran more or less the same but the carbs were really leaky. Went through and cut my own gaskets for everything because I loathe taking carbs off over and over. (I had rebuilt each of the carbs as well, needle, seat, jets, etc)
So, present day.
The choke is not assisting the cold start at all (i found that this probably meant that the mixture was lean), and there begins my problems. Out of frustration, anger and giving up, i have forgotten where they were when they worked well enough to be a starting point, not that those settings were at all correct. Currently the bike does not like to start easily (with some starter fluid and some gassing the throttle it will rev up), once it starts once and warms up a bit it will kick start no problem The choke does not assist the start up what so ever, if anything it keeps it from starting. And when the bike is finally warmed up, the opening of the choke will kill it.
The bike has Mark 2 carbs, airbox is as sealed as i can physically get it, boots are good, spark is good, compression is good.
Any help or assistance will be greatly appreciated, i really just need a ballpark of where to set the screws to begin fine tuning. I feel like i am just chasing my tail with every day i work on it feeling like ive solved the problem, just to start again with a cold engine the next day.
Thanks
So, present day.
Thanks
