MOFSET R/R wiring?
wannabridin
XS650 Guru
XS650.com Supporter
Hurst, TX
Hey guys, wondering if someone could help me determine the wiring for this Reg/Rect I have from my PMA swap. Anyone have some thoughts?? Thanks!
3 yellows are stator to rectifier. Black is gnd. Red is power from batt to regulator. No idea on the green.
You sure that's not for a non-PMA system? Green would be for the brush in an energized rotor system.
yellows to the stator, red to the positive terminal on battery you should put in a 20amp in-line fuse, green to battery negative, and black to the original switched live that fed the original alternator, if you don't have the original harness connect it to another switched live, i had this set up on my last XS, got mine from a chap in Wales that puts them together.
