I run a diesel heater in the winter to heat my garage. This year my sister and brother in law donated a good qty home heating oil from their removed furnace. I wanted to try it before the real cold weather hit so I dug out my heater to test the new fuel. I drained it at the end of this past winter so I expected it would require priming.
I forgot the priming sequence but found it quickly on line. I started up the heater and got quite a bit of smoke from the exhaust but was confident it would burn off. The unit kept shutting down and I primed it several times. Eventually it hardly ran and fuel oil was leaking rapidly from under the cover. I figured it was the result of too much priming.
I had no choice but to take the heater apart and found an unpleasant surprise. Mice had been feeding inside my heater and chewed through the insulation a on a handful of wires. Then they decided to gnaw through the nylon fuel line. That’s where the fuel was leaking from.
I figured I could just put heat shrink tube over the bare spots on the wires. Tape wouldn’t work because of the possible exposure to fuel. I didn’t want to cut the wires and rejoin them so I released the connectors from the plastic plugs. That was quite the chore. I had the release tools but they didn’t work as well as would have expected.
Wires are now protected and I cut out about 6” of bad fuel line. High temp silicone is curing overnight and I’ll retest it tomorrow. Next spring the heater will be stored on the garage for the summer.
I hate those rodents.
