jaybar6
Using the magic of GIMP, I want to move the engine back about an inch and straighten the engine up like it was when it was first designed. The picture shows the engine moved back and how much metal needs to be removed. It is now hard up against the three tubes - one the swinging arm pivot, the other two footrest and brake lever respectively. This entails a swinging arm pivot hard up against the engine and closest to the engine sprocket (not shown, it's on the other-side obviously). This has the advantage of reducing chain ware. The tilting of the engine according to GIMP is about 11 degrees. This would add cooling of the engine as the air can now flow through the fins.
