B-blood red
D-de black one.
D-de black one.
Thanks for that. The strobe will trigger at cranking speed (it has an induction clip you out on the HT lead) ? The plugs are cable tied to the big acorn nuts on the heads, they're well grounded and the sparks are big fat ones. Voltage on the igniter is good, direct from the battery via a relay.You can check timing with a timing light, cranking plugs out but grounded. Try a bit of carb cleaner sprayed in the intakes? That'll narrow it down if it fires.
Raymond, will the strobe induction pick up actually trigger off the HT lead at cranking speed? Thanks.My vote goes to checking timing with a strobe.
I'll know in the morning. Not sure what I'll find as the static timing is spot on per BB instructions.I think so . . .
Stock rotor.What charging rotor?
How is the advance rod locked to the cam? I'm thinking, looking for a slipping shaft part moving the timing.as they always say 3 things spark, fuel, compression.
No, mechanical advance is removed. The entire advance and points system is removed. In it's place an 8mm threaded rod passes through the camshaft bore. On the right side there's a Bush to keep the 8mm rod centred. On the left there's the magnetic rotor. Timing is set statically at full advance and it relies solely on friction to keep the correct timing. Spark retard/advance is done in the blue igniter box.This uses the mechanical advance? That mechanism working smoothly?
You're describing my concern there. Just ordered a compression tester.Compression enough to run well can be felt via the kick starter. Kicking down slow it should feel like a spring as piston comes up, mostly stopping progress and not just hissing through TDC.
Coming up on one cylinder reset the lever and you should get two bumps (compression strokes) on the way down.
Thanks Paul. There's a few extremely poor design details in the BB kit and I'll definitely air my thoughts one day.That BB 8mm rod is just so amateur and the PCB too thin and flexible, but the system worked extremely well on my SH...I did make up some bushings to force the 8mm rod to center better and be more secure. In the past there had been criticism about the Gill ignition coils supplied with the BB kits. BB told me they not seen an issue. My research lead me to conclude that the issue with the Gill coil on other motorcycles was due to sparkplug gaps being set too large and straining the coil i.e. greater than 0.75mm.
Thanks. I've done that (pushing the bush home). Obviously there's tolerances involved, mine was an easy push fit. Didn't really need any tapping.My long distance,
haven't read the instructionsvote is the bolted rod slowly slipped out of position in spite of "static timing hasn't changed".
An interesting line: Place a 13mm socket over the nut & sharply tap the end, this will drive the right hand bearing bush home into the
camshaft before fully tightening the rotor stud.
