You guys keep beating on the threaded rod. Guess what? It does it's job. All it does is hold the rotor in place, it's not driving a gear or anything with a lot of resistance. Is it the best design maybe not but it works. The stator plate just be careful installing it. I have had to file the edges a little so it could seat better.
I've installed 5 Boyers of them over the last 5 years have not had a problem with any of them. None have had the timing move at all. No stator plate or coil problems.
A lot of times that paint dot you use to static set the timing is not in the exact right place. Usually retarded some. You may find when you check it with a timing light that it is off.
Something I do if I have to remove the stator for any reason after I have the final set on the timing is put the engine at TDC and put a mark on the rotor and a corresponding mark on the cam housing. Then when I put it back together I know where to put it.
