After domestic chores, I got to start disassembling the clutch to do the start motor grinding fix.
First thing I found was the clutch spring screws are a very good fit on a JIS 2 screwdriver bit. Second thing I found was pounding the screws via a solid steel JIS 2 screwdriver with a 4lb lump hammer conditioned the screws such that they very easily came undone. Maybe I was lucky but the screws did come out really easily. No need today for an impact driver. (To clarify, when I say pounding the screws with a 4lb lump hammer, I mean using the weight of the hammer. Definitely not like you're trying to destroy the clutch).
So, the springs and pressure plate came off in a couple of minutes. To reveal the centre nut and the plates. A couple of notable things here. This is the first XS650 clutch I've opened up. I was expecting to find a tab washer on the centre nut. But there isn't one. Mine has a belville washer and a plain washer under the nut. Obviously, at some point this changed from a tab washer? I don't know when.
Snag is, I can't go any further today because I don't have a 29mm socket. I have ordered one but it will be next week now before I can remove the clutch basket to get at the start motor grinding problem.
On the plus side, the friction plates and springs are within spec. Plates 3.07 v 2.7mm, springs 34.7 v 34.6mm.
Maybe I'll look for someone locally with a lathe and do the modification to take M6 x 40mm cap head screws modification on the pressure plate while I wait for the 29mm socket to arrive. Pictures-
