I've been slowly working on this exhaust system for over a week now and it's been a real challenge especially for someone with my metalworking skills which amounts to drilling holes and some pretty average filing.
I had to try and work out how to get a decent mounting bracket onto the mufflers as the ones supplied in Mikes kit were useless, they were lucky to be 2" long and I needed ones about 10 " long.
Here's what I came up with, drilling the brackets.
I decided to fix these 2 long brackets to the original chrome muffler mounts and then spaced them out 20mm to allow the ends of the mufflers enough room so as not to touch the lower shock mounts.
Those brackets that slide into the muffler mounts allowing for a stronger connection were not in the package I received from Mikes so I emailed them and they said they would send some, the package turned up today with 1!! in it, I can't win with this system.
I bought this system because I wanted something that was going to be a simple bolt on installation and it definitely hasn't been that.
Another thing I just remembered, the header pipes don't come with the lower mounting tab like the originals they have to mount onto the supplied brackets with a chrome clamp similar to the muffler clamp.
Also found to mount the mufflers onto the headers they are too loose if you use 2 of the reducer rings and won't fit on with all 3, I had to scrounge around and find a piece of thin walled pipe to fit over the headers and then fit the 2 larger reducers.
These pics are just some I took today whilst test fitting, will post some more when it is fitted up permanently.
