1. Having trouble logging in? Try closing your browser and re-opening it. If that doesn't work, try a different browser or device. The site will be updated soon to resolve these browser issues.
    Dismiss Notice
  2. Dismiss Notice
My Summer 2021 Chopper Build 1976 XS650...but... a small issue
Discussion in 'The Garage' started by freakchopper, Oct 22, 2021.
  1. freakchopper
    freakchopper XS650 Enthusiast
    I can't get it started. I installed a ... New fuel tank, New Fuel Line, New Spark Plugs, New Battery ... although it came with a Hughes PMA already installed. Previous owner said it had a no spark issue. Check out the photos ..any advice or criticism is appreciated.
    Scripto VU and gggGary like this.
  2. freakchopper
    Does anyone know what the toggle switch on the right of the ignition is for ? ... it has 3 positions. 20211022_190550.jpg
    Boog likes this.
  3. freakchopper
    Boog likes this.
  4. Jan_P
    Jan_P XS650 Guru Top Contributor
    1,142
    1,661
    163
    Sweden
    Is there a hole there If so It perhaps needs a patch pipe over it
    Cylinder head looks like leaking need tightening
    Boog likes this.
  5. freakchopper
    ok...on that particular picture I just wanted to know what the toggle switch to the right of the ignition was for ..it has 3 positions. ..not sure if it has something to do with the Hughes PMA ignition system..??
  6. gggGary
    gggGary On the road of life I'm a speed bump. XS650.com Supporter Top Contributor
    best guess on toggle is headlight. but start tracing wires cuz; custom.
    Lets see inside that round cover on the end of the cam.
    While you're at it lets see inside the lower round cover too.
    [​IMG]
    Boog likes this.
  7. freakchopper
  8. gggGary
    Jim likes this.
  9. Jim
    No wires from the cam cover. Looks to be crank fired whatever it is.
    gggGary likes this.
  10. gggGary
    freakchopper and Jim like this.
  11. gggGary
    here's a hand drawn diagram found on here, should be enough to check your wiring.
    [​IMG]
    Boog and freakchopper like this.
  12. freakchopper
    hi..thnks all .... it is a kickstart. No electronic ignition. Correction..I meant Hughes charging not Hughes ignition. This is my first experience with an xs650, kickstarts and the Hughes PMA ( not familiar with any of this) . I am doing this on the fly. I will use that diagram and do some checking. I just don't have any idea if it is the Hughes system or something else. When I go to kick it ..it seems pretty dam dead to me. I don't even know if I'm kickstarting hard enough ..?
  13. freakchopper
    Also..I have a Mikuni carburetor on this bike... when I went to fill the fuel tank for the first time , I noticed fuel was leaking out of the rubber lines coming out of the carburetor. The leaking stopped after awhile. Is this normal ?
  14. WideAWAKE
    WideAWAKE Single Fins and Twin Cylinders
    Seems like it may be a good idea to do some investigation and sort out what all your parts are before trying to drive the thing down the road.
    Kickstart only means no electric start, not no electronic ignition.
    get an absolute base line for all the things you have. Then you can try to understand how they play with each other.
    Seems you’ve little experience with these (or motorcycles in general) and a highly modified bike by a PO that based on the pics didn’t seem to do such a stellar job. That can certainly be an uphill battle if you don’t take your time. You don’t want it ending up in a sidelined project or one that spends all its time getting fixed and never ridden.
    None of this is a shot at you, just a suggestion to pump the brakes and move slow (you could be sorting this bike out for months to make it reliable) prepare for a long haul. If it’s quicker, all the better!
    2BallCane, gggGary and freakchopper like this.
  15. freakchopper
    ..sound advice...appreciate it !!
    gggGary likes this.
  16. Jim
    Following Gary's advice and giving us some pics of what's under the engine covers would go a looong way toward figuring this out.
  17. freakchopper
    Previous owner did say he could not get any spark .. I changed the plugs hoping that would solve the issue, but it still didn't fire up. These are the plugs I installed
  18. freakchopper
    will do !
    gggGary likes this.
Share This Page
