So I got the bike running pretty good . Without baffles that is. I have dual 1.5 inch open exhaust, but I had put a set of slightly modified eBay baffles in. I have a 35 pilot 180 main and I have the clip four down on the jet needle. I have played with it 5 down and I believe 3 down. I think It was 3 down with everything else the same as before I did the installed the big bore kit. I'm 1 turn out and I have checked the throttle cable . I have volocity stacks on it with a screen in front and another screen with a piece of foam in front of it for the filter. I have the aftermarket aluminium to hose intake? So you know it ran great last year pretty much the same way minus 1 position on the jet needle (I think). So here's the problem the bike idles fine and when I get past 1/4 throttle it's good to but right when your turning the throttle in every gear or at least first second and third it seems to stumble and buck . It's worse if you are getting going on a incline. It reminds me of when I learned to drive a standard for the first time. It's not terrible and I get through it but I'd like to get it right. I'm leaning towards ordering a set of 37.5 pilot jets . With that said I'm gonna order a set of longer baffles to quite it down and retune it but until then I need to ride it. I would like to get a good setting here because it may take a while to get the a sound I like. I haven't had any luck getting it to sound good. Also it's worth mentioning that yesterday when I started this process I was trying different amounts of fiberglass around the baffles to get it running right . It wasn't until I pulled them out that the bike came alive. It sounds a lot better with no baffles then it did before. Going from 650cc to 750cc made a big difference in the sound the bike makes. Anyways I'm sure this has been asked before but I never have much luck searching the forum, so if you can point me in the right direction of just give me your opinion that would be great . Thanks. I put a couple pic up to.
