Needle roller bearing swingarm pivot
festerandolini
Victoria, Australia
I have the all balls kit to convert my swing arm to needle roller bearing, and i had tried to install them already, but tapping the bearing in on the first side, forced the rollers out onto the filthy floor of my shed.
What is the best way to install these needle rollers? Have many people performed this mod?
Or should i just install the bronze bush set instead? It seems much easier.
Never used needle rollers. I would persevere with what you have (if you can find all the rollers) have a look on YouTube about installing them if you dont get the info you need here.
Bronze bushes are fine if they in good order, the swing arm does not rotate very far or fast. New bronze bushes are easy to install.
Thank you. I will see how far i can get, and hopefully i dont crush the cages. The bronze bushes look very easy to install. I should be able to get some of the needle rollers from the bearing supply, if i lose any. I will give them a clean, slug some more grease into the cage and use the axle tube as an internal barrier... Maybe that will help.
Used the same kit myself- - dead easy if done right :0)
Heat on Swing arm - needle bearings in freezer overnight
Pull them into place with a length of threaded bar and suitable sized sockets
Job done
Basically a makeshift puller to install. It's the correct method rather than driving with hammer. Slow steady guided pressure.
That said I've owned bikes with both bronze bushing and needle bearing swingarm pivots and the general consensus is that needle rollers are probably not the best application. The amount of rolling of the needles is minimal and over time they'll wear into the races and not be as secure as solid bushings.
My XS1100 swingarm rides on conical roller bearings. I think the torque applied to them is in inch pounds. The frame is much different than that of the XS650. The torque applied to the swingarm bolt on the XS650 is pretty high. Could that preclude use of needle bearings. Right or wrong, it does for me.
FWIW, you have to ride a lot of miles with no grease to wear out the OE (plastic?) bushes.
The original glass fibre nylon bushes had worn loose. I am not sure of the exact miles of my bike, as the odo i am pretty sure read around 60k k/m.
The wear and tear on the bike is consistent with that, but it looks like tha last 20k where rough, with few maintenance intervals.
The bike was either stored in an open shed/carport, or it was stored outside. The instrument cluster is very faded and cracked, the seat deteriorated and for the last few years it was stored in a pile, that had become a rat home.
I am not adverse to fitting the bronze bush. But i will give the threaded rod method a go first.
Edit: i checked the runout on the original bushes and they where out of spec. I had dry fitted everything and found there was a bit of play. I will see if i can make it work with the kit i have, and when i balls it up, i will try something else.
I did not intend to imply that you should keep your original bushes or replace with OE. Only that they do their job. If they aren’t broken, I don’t fix them. Once the swingarm is out, I go to bronze. Just be sure everything is well lubed and correctly installed. I added a grease track to my assembly.
Swingarm setup has been covered on this forum in detail.
My experience.
https://www.xs650.com/threads/swingarm-play-pivot-bolt-damage.61232/
Pay particular attention to posts by grizld1
My experience.
The swingarm was out when i got it. But if it was in better condition i would have left it.
