Neutral light always on and flasher blows fuses. 75
mm1ut1
sheboygan, Wi
My 75 neutral light is always on. Also the flasher relay buzzed like crazy and the left blinkers didn’t work. I bought a three prong relay at an auto parts store and now it blows the main fuse when I try either side of the turn signals. Should I get the neutral light fixed first or the turn signals? Any chance they could be related?
My 75 neutral light is always on..... Any chance they could be related?
I'm assuming you mean even when in gear, the light is on?
Most likely not related.
The neutral light comes on from the neutral switch going to ground (providing a ground). So if your light is always on, there's a short somewhere downstream of the light. I'd start by disconnecting the switch and see if the light goes out. If it does, the switch is most likely shorted internally.
If the light stays on with the switch disconnected, you'll have to chase the wire back to the light and find where it's shorted or wired incorrectly.
Have you looked in Tech or did a forum search? Something sticks in the back of my mind that you need to switch two of the wires at the relay connector..... 'though I'm not sure if I'm remembering that correctly.
I had to do that when I fitted a standard three terminal automotive flasher relay in my 650D. There's a post on here somewhere detailing the wires I switched in the terminal block.
Edited to say - here's a link to what I did.
https://www.xs650.com/threads/turn-signal-issue.66381/post-839620
I'd be looking at the solder blobs on the LH handlebar control. A loose wire may be grounding.
I checked the light switch today. Everything looked good. Checked the left turn signal bulbs. Left rear had corrosion so I cleaned it up. I finally ordered a new neutral switch cover as the old one was rock hard. Dangitall! Spring is around the corner and lots to do!
Well that's a head scratcher... :umm:
Yeah, it was a challenge. I ended up getting an unmolested main harness off Ebay, but figuring out what others had done inside the bucket was a nightmare. I've got a lot of pics like this in the inventory from getting it sorted out. Matching what I had against whichever diagram they seemed to jive with.
