The frame has been altered welded and painted. The race motor has been installed.
Been quite busy doing little jobs finishing off the wheels making bearing spacers, hub bushes etc. the 13 inch diameter rims are within the rules for our class but allow for a wider tyre which is a bonus.
The rear sprocket has been sorted just need to drill the bolts for lockwire and mount it. The rear tyre has been reversed and is now in the correct direction.
The motor is in the frame and work has began on building the pipes, using a 2 into 1 to see how it goes at this stage. No real design just making something that fits.
I have made a rotor and pick ups for the ignition, going to use an Ignitech it will allow for easy adjustments when we start to run methanol. I used my rephased road bike with a cam driven ignition to bench test the initial programming. I slowly realised that the Scitsu tach for the old rephased motor would read 2x now that we have gone from a cam fired ignition to a crank fired unit.
However the tacho of the 700 being for a two stroke would now work fine.
Been through the carbs checked float heights and upped the main jet to a 200 as a starting point. Replaced the broken front brake lever and serviced the calipers. Surprisingly most of the callipers were semi seized so cleaned and serviced them so they move freely now. While I had the discs off I took the opportunity to bead blast them.
Some time later,
the pipes are finished just need painting, the oil containment tray is almost done. Now trying to work out a mount for the fuel pump, its an electric on a carb model Honda CBR600. These are the go to pump for the classic sidecars in Europe no need for a regulator. A couple of the outfits here run them without issues so have gone away from the pulse pump. I spent an age today making a fuel T for the carbs.
Mounted a LED for the neutral light and fitted the decompressor lever (the lever is for a small childs push bike), rechecked that there are no collisions with the lever pulled by turning the motor over by hand.
Earlier I rechecked the cam timing because I had convinced myself it was 1 tooth off. Rechecked the timing and the cam had been installed correctly.
A mate is repairing and repainting the body work as we are running out of time the next meeting is at the end of the month and both of us are busy with work.
There is still a lot to do and we need to get the Technical Steward round to sign the bike off.
