New here could use help
TiggerOG
XS650 New Member
Georgia
I have an 80 year model that im trying to get running and best i can tell is that I suddenly lost spark. Testing the pick up coil leads me to believe that one side is out of spec and the reason why. Black to gray is 723ohms and black to orange is 3.66kohm. Any chance someone can guide me to where I can get this part as im not having much luck finding one.
Thanks IBALT. I guess this is the weak link on the later models. The alternative being points conversion? Nothing wrong with points. What parts does it require. Backing plate and points cam, advance mechanism? A project but possible.
Edit: Gonzo? I know a lot of this can be found in TECH or ask google, I'm working my way through theese old threads but posting in current threads can be helpful?
Most Gonzo conversions rely on the stock pick ups that are noted as being more reliable than the TCI box.
OP; take your sharp probes and recheck by poking the wires AT the pick ups. See if they are in spec when measured up there. broken wires in the harness near the drive sprocket are a known, if not real common issue.
Well worth checking what gggG says ^^^^^^^
Personally, I definitely wouldn't convert from TCI to points. The points, condensers etc... on the market today in the aftermarket have never been poorer quality. Certainly nowhere near the kind of reliable product we had in the 1970s.
If I had to convert a TCI bike away from the Yamaha system, for me it would be a toss up between Boyer Bransden and TriSpark. But only if I couldn't get the TCI system working.
