New project : 1975 Suzuki T500 Titan
OMG Vic, you are a bundle of energy! Good on you! I look forward to learning more about this bike. It sounds and looks great! I can't wait for retirement. Next year...
Looking forward to your next trip to Ontario John. Hopefully the stable will still be full of interesting stuff.
Yes, 1976. Moved a front end over from the GT550 (albeit slightly shorter) adding a front disc and jettisoning the weird, tapered forks and the nice-looking twin leading shoe drum brake.
I’ve always been fond of the look of the twin leading shoe front brake. I’ll make sure mine will be all cleaned up soon.
Thought you might enjoy this. I found the first published road test of what they called the 500/FIVE ( at that time ).
The link below will take you to Cycle Worlds library, specifically this issue and you can read the whole thing. It’s a real time capsule of bikes, riding gear and life in the 60’s. The advertisement pictured is from that issue.
https://magazine.cycleworld.com/issue/19671201#!&pid=44
View attachment 375112View attachment 375113View attachment 375114
Just read this. Interesting. Thx for sharing.
I need to replace fuel and oil lines. Seems Mr Suzuki thought 5.5mm would be better than 1/4” or 3/16”. I usually use Tygon tube but I’m doubting I can find it in 7/32” ID. The beetle also uses 5.5mm and I bought some for that application. The VW stuff is fairly thick rubber with a cloth cover (apoears to be German thing - BMW uses the same. Any recommendations for fuel line sources. I suppose I could try to squeeze down the 1/4” or stretch the 3/16” but would rather find a better fitting solution.
A bit more research and looks like it’s a common size on Honda. I’ve yet to find a domestic source for it though.
I know I said I wasn’t going to work on it until the winter but it kept calling my name. Done today:
- carbs off - actually clean inside but I’ll give them the once over anyway
- repaired RR signal light - wouldn’t tighten in the proper position do I had to disassemble it to fix that. The reflector wasn’t reflecting anymore so a quick clean and spray with chrome in a can made it look better.
- tried cleaning the pipes but I might be stuck with the nastiness. On the way home from the cottage I stopped by to see a guy I know and returned with a couple of pipes with better chrome but more dents.
- replaced the ill fitting oil line - I decided to stretch 3/16 Tygon
- compression test - happy with the results.
- this bike was owned by a mechanic. Lots of shoddy workmanship found a several loose bolts already. A once over is definitely in order.
I’ll try to order some carb bits. Main thing is bowl gaskets. The rest looks good. I like the simplicity of the Mikuni VM slide carbs.
It’s starting to look better already. I’m going to try polishing the top of the tank. It may shine up enough to keep me happy. Fingers crossed.
IMG_4819.jpegIMG_4820.jpegIMG_4821.jpegIMG_4806.jpegIMG_4807.jpegIMG_4811.jpegIMG_4817.jpegIMG_4818.jpegIMG_4804.jpeg
I have owned my 71 T500j for the past 30 years. They are a very good & reliable bike.
With strong torque.
But beware! If your's has been standing idle for any length of time, the crankshaft oil seals will be shot. I have just paid £700. Sterling to have my crankshaft rebuilt.
The centre bearings get their lubrication from the gearbox. So if the seals fail, oil will be sucked from the gearbox destroying 4th & 5th gears.
Good luck with your project.
Do you get Brasso or Silvo stateside? It's like cotton wadding impregnated with polish - really good at shining up metal, no scratching. Silvo would be the one for chrome. Recommended.
We used to be able to buy both Brasso and Silvio here decades ago for sure - Mom used to use Silvo to shine up her good cutlery. I’ll look to see if it’s still for sale around here. I can still remember the smell.
Edit - both still sold here.
With strong torque.
I had a T500 as a 17 year old. It was going through tranny oil. Sold it on with a warning about keeping the tranny oil full. Advice ignored, the tranny ate itself. Didn't know about the devious crank bearing lube scheme.....
I met a guy this morning who had first hand knowledge of the mechanical history of my bike. The engine rebuild included new main bearings, new crank seals, nee pistons, rings and rods. Hopefully this will be s good runner! Carb bowl gaskets on their way. I may do the carb refresh over the next couple of days.
