I put Shinko 777s on my bike, very happy with the handling, spirited or cruising.
Cons they are not period correct.
Glass would good but all the jars I have are with a steel lid. Maybe a couple of layers of plastic between the jar and lid?I wouldn't trust plastic unless I knew the chemical composition of the stripper. Nothing will touch glass, on the other hand. Just my $0.02...
I would shoot a coat of high quality clear and call it done.One tank badge done. Two coats of paint. Maybe a 3rd? Looks much better.
View attachment 376368View attachment 376369View attachment 376370
I was thinking a 6 mil polyethylene vapour barrier plastic.I would shoot a coat of high quality clear and call it done.
As for plastic (assume you mean Glad, Saran, etc) protecting the metal lids, I think whatever that stuff is would eat that thin plastic in ~2 seconds
Yes, that might work. Would be easy to give it a test, just dab some on a piece and you'll probably know pretty quickly...I was thinking a 6 mil polyethylene vapour barrier plastic.
I have had good success with this. But for any high quality aerosol clear, ensure the base paint has ample time to cure (~3+ days) regardless of what the label says. And spray just a skim coat first and let it cure some before recoating. Not doing this risks the solvents in the clear fu(king the base coating(s). Don't ask me how I know.Yes I was thinking about clear coating it but would need to buy some. I have some 2K clear but once I crack open the can it’s done in a couple of days. I’ll check at the auto parts store.
After "the treatment", I very often coat the underside with silver/gray Rustbullet or POR-15.The show side looks pretty good but I noticed a lot of surface rust underneath. I guess I’ll remove it and give it the treatment.
Yes on my beetle project I cleaned the surfaces with a wire wheel, washed with alcohol, painted with POR15 then top coated with silver (chrome in a can) paint. With the fender maybe I’ll spray it with gravel guard / undercoating?After "the treatment", I very often coat the underside with silver/gray Rustbullet or POR-15.
Dunno... guess you could always take up basket weaving... for a winter project...Now off with the fender. Maybe I should wait until I complete my beetle stuff?![]()
Or buy that other bike I’ve been eyeballing!Dunno... guess you could always take up basket weaving... for a winter project...
