OK, now I'm not so happy.
Here's what I've done this afternoon trying to improve the misfiring right side cylinder -
1 Swapped plug leads left to right after fitting two new spark plugs. (Then swapped them back, wasted spark ignition).
2 Tried pilot mixture screw adjustment between 1 and 3 turns out. (I started off at 2 turns out).
3 Double checked air leaks and replaced a suspect vacuum connection blank.
4 Swapped diaphragm and needles left to right.
5 Tried choke in several partial positions.
All revs from tickover to 3000, still same misfiring. I can actually feel a pulse as it misfires if I touch the carb top while the engine is running.
None of that made the slightest difference to how it runs.
I don't think I've got any alternative now other than remove the carb set again and go through the air/fuel passages on the right side carb. I have a sinking feeling here that right at the start when I extracted the seized mixture screw, there's something there that I haven't yet noticed?
Edited to add - the mixture screws on CVK34 are a pain to get to on the bike. So I've just ordered a pair of mixture screws with an extended shank that has a knurled grip at the end. Makes adjustment of the mixture screws so much easier. Should have bought them before now.
