Hi, I am preparing to install a set of Gpz carbs to my XS. Nowhere in this thread has anyone mentioned replacing the needle jet. Does anyone know if the pwk28 needle jet will fit the cvk34? or do I fit the cvk34 needle jet & it'll work fine with the jjj needles.
I dont know much about carburetors
Are we talking the Motorcycle Kawasaki GPZ carburetors when the thread is about EX500 carbs.
But if the GPZ is a sport bike .Is there not a risk for problems
The XS 650 cruises at 3-5 k rpm Perhaps not GPZ
I dont believe heard of GPZ c
Same Same But Different! Read the complete thread, it'll answer all your questions.I dont know much about carburetors
I dont believe heard of GPZ carbs used
They're certainly working just fine for meCVK34's, great conversion!
Mine are set exactly the same and there's no issue with overflow or leaking. The float valve seats are not replaceable on CVK34 carbs. Best you can do is clean them thoroughly with a cotton wool bud making sure you leave no bits behind off the bud. Are you 100% certain that the floats aren't taking in fuel internally? I see that you fitted new floats, but worth a check. The float valves you fitted, are they genuine Keihin? There's a lot of rubbish around in the market. I used Keyster parts, they're working well.I have just fitted a set of gpz500 carbs to mine with the suggested jetting and it's a big improvement on the previous ones. However I am getting both carbs leaking from the rear hole suggesting the float valves aren't cutting off the fuel. I set the floats to 17mm as per the Kawasaki. Am I in error or am I unlucky enough to have two knackered float valve seats? I put new floats and valves in and have cleaned the carbs in an ultrasonic bath. Despite looking a fairly clean set the bath took off a load of filth.
i have had the exact same issues, eventually bought OEM needles. Set to 19mm instead of 17 to see if lowering fuel level would work. Then I used a ss ball & peened it in the seats to maybe take out any ovalness to it. I'm leaning toward some sort of seal between the seats and carb bodies leaking.Best Chinesium valves. The floats are not holed. The seats are press fit so will likely come out with a tap. Some press fit seats use an o ring to seal to the body to keep fuel from going down the sides and I'm wondering if the carbs have them and if they've died. The valves offer resistance and appear to seal when upside down and the weight of the floats closing them to me blowing through the fuel line.
Made of brass and a press fit. Look like the type that typically comes out via running a tap down until it bottoms then twist and pull till out and often have an o ring sealing them to the bodyI think you're going to find that the needle valve seats are cast into the carburettor body.
How did you get them out? I was thinking either freezer or ovenGot them out. Doesn't look like a leak past them so likely the seats. Not any of the common seat types available though.
