The only cleaning solutions for brake fluid containing systems are: WSW rinsed with clear water, clear water or the correct brake fluid. There are reasons that master cylinders state which type brake fluid to use. Now for the story, A few years back in the '60s I drove a MGB and had hydraulic clutch issues. I purchased the rebuild kit and rebuilt both master and slave used kerosene for cleaning and fresh, plain old brake fluid, the master cylinder stated use only Girling approved brake fluid. Guess what, the rubbers in both cylinders turned to GOO in 2 weeks and failed. Rebuilt them again, thinking must be bad rubbers. Same procedure, same result. Did some studying and got some education, brake fluids are not the same, they absorb water and are not compatible with petroleum based solvents. Rebuilt the cylinders again using proper solvent WSW rinsed in water, the problem never reappeared. Using the correct solvents, lubricants and fluids in your brakes can save your life.
john
