No power to fuse box or capacitor?
Looked at the factory guide and somewhere around an ohm between the two yellows when disconnected from the regulator should be about right. Open circuit or a high number would prolly mean you've found the problem.
Haven't seen the numbers, but guessing the ignition coils are wound to create a higher voltage on this and the vape units as compared to the "lighting" coils with the yellow wires.
