nomad007
1980 xs650 special - sorted out charging issues went on 85 mile ride ran great - have voltmeter everything was good until end then felt like it wanted to stall- removed coil - posted on here member said it was probably mikes XS not original. while removing cow; wire came out of coil back. Bought MP08 on eBay - it metered correctly - new plugs ,caps and wires - no start. Seemed like only one side was getting spark and it was ok but not awesome blue. well red and white connector has power - orange wire does not. I think iI followed it back to same wire there was an orange connector in front of battery behind seat I unplugged sprayed with contact cleaner no power there. I did just replace rotor - messed with regulator and stator. Maybe I loosened something. Anyway I assume it is supposed to have power and is contributing to the no start. Before I figured this out I had the air boxes off and sprayed starter fluid in carbs to rule out a fuel issue, The carbs have seemed great tho - great idle and usually start, I did also replace the original vacuum petcock with manual as it was dripping on the on position when I had taken it off to work on battery issues. I did pug vacuum line. Any help would be appreciated. I have only had this bile a few months and did get to put several hundred miles on iy so far but now I guess I am getting to all the gremlins. thx Damon
