nomad007
Hi Everyone,Since you got them both turning, I don't see the need for that extractor, and like you said, there's more of a chance of damaging (and maybe even ruining) the carb body with that. Just keep at it with the penetrating oil and heat. What penetrating oil are you using? PB Blaster is pretty good but Kroil is even better. I'd say they need to come out so you can replace the o-ring at the bottom. That's what seals the screw in the hole and if it's bad, the mix screw won't function correctly.
Yes, when screwed in all the way and lightly "seated", the tip of the mix screw will hang out into the main bore a little bit, like so .....
But, a stock bike with stock size pilots runs best with the screws set between 3 and 3.5 turns out, so you wouldn't see the screw's tip then. Even a modded bike with larger pilots still likes 2 to 2.5 turns out.
well I got the Kroil. and took my time soaking the mixture screw for days removed the one with the choke knob side. those rennsteig extractors are nice. I am afraid the right side is probably buggered. It is a shame because these carbs are very clean. Neither of the screws had springs btw. Is that how they came from the factory. Does anyone by chance have a right side 1980 xs650 special carb they would be willing to sell? I have seen some on eBay but a lot are crusty. Am I wrong in assuming I can just plug in a new right side carb body of the same model? At least I am learning a lot and again thanks for all the great advice. On a brighter note I was given a titled 1976 cb 750 with a powder coated frame and running engine with 14000 miles. It needs a tank and a front end tho but it was free. Now I have 3 non running projects . Thanks Damon
