No spark issue
brianis
greeley co
Ok guys 1981 650 special bike was running great put it in the living room for winter. Wheeled it out last week it started then died and now has no spark. I did the simplified wiring on it. I had to replace the battery and replaced the coil as it wasn’t homing out thought awesome now it will start nope. So here I am I have power at the primary coil if I connect a test light to the primary side and crank I can see the light dim with the cranks. So i then moved to the brushes they have power. Next checked to make sure the tci ignition has power and it does. Just checked the ohms at the 3 leads of the field coil they tested around .700 ohms so should be close ish. I’m starting to think maybe my tci shit the bed
